AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant3D 2014 create Equipment : nozzle scale problem
3 REPLIES 3
dyemz113
615 Views, 3 Replies
 I'm new to plant 3d.  My problem arises when I tried to insert a new equipment and the nozzles were drawn at a really big scale.  I know the problem lies somewhere in my scale parameters but couldn't really point at which one.  Need some advise on this one. Thanks
3 REPLIES 3
patpat79
in reply to: dyemz113
If your project is imperial, use inches as default unit in your drawing.. if metric, use millimeters, you can verify your drawing units by typing "un" or "units" command
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
dyemz113
@patpat79. Thank you. I made a new project and applied what you have said. The problem lies that the dwg files i was integrating were from different standards: one was in imperial and the other is metric, and the project file was in meters.
patpat79
Welcome, have a good going project.
Best Regards,
Pat Andres
GHD Manila
”Boost
