AutoCAD Plant 3D General DIscussion
Valued Contributor
phwatso
Message 1 of 2 (205 Views)
Plant Spec Update Check
205 Views, 1 Replies
12-06-2011 03:16 AM
The command plantspecupdatecheck which now runs automatically seems to lose the tag number of the valves etc. after it has run.
Product Support
Dan.Scales
Message 2 of 2 (158 Views)
Re: Plant Spec Update Check
12-21-2011 08:41 AM in reply to: phwatso
This issue is currently under investigation by our development team.
Unfortunately the only suggestion I can make to help workaround this is to export the tag information from the data manager and re-import it after the spec update.
Dan
Dan Scales
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
