AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant Piping problem with auto TEE
2 REPLIES 2
dzine14u
1225 Views, 2 Replies
After the tedious task of creating our very first comprehensive piping spec (and debugging) I am only encountering one major issue...
When I click on the "+" on a pipe or when I run a pipe into another pipe it should create tee automatically.  Instead, the pipe simply terminates at the pipe junction with no tee, however, it shows it as being connected with no errors.  We do have all of our tees specified but cannot find the problem to correct this.
Additional info:  We are using BV welded fittings
Chuck Altmix
Lead Engineering Designer
Upper Consulting, Inc.
www.upperconsulting.com
2 REPLIES 2
jabowabo
in reply to: dzine14u
Did you populate the branch table for the spec?
dzine14u
in reply to: jabowabo
Thank you Jabawabo...that was it.  Problem solved.
Chuck Altmix
”Boost
