AutoCAD Plant 3D General DIscussion
Active Contributor
roryromano
Message 1 of 5 (199 Views)
PLANT DESIGN SUITE 2013 PROBLEMS Navisworks
199 Views, 4 Replies
04-26-2012 05:34 PM
hello,
I have just recently upgraded from 'Plant design suite 2012' to 2013.
Had 2013 working great and it looks to have some great improvement from 2012.
BUT...
--2013 Navisworks has stopped refreshing. Was working perfectly one day then literally stopped working.
 i have ran all sorts of test and tried all sorts of settings but no luck. i have many years of experience with navisworks. it literally worked one day then the next day stopped working...
help!!
thanks
rory
Active Member
joneriksen
Message 2 of 5 (189 Views)
Re: PLANT DESIGN SUITE 2013 PROBLEMS Navisworks
04-26-2012 11:05 PM in reply to: roryromano
I haw same problem. Solution will be weary helpful.
I haw tried to attach xref instead of overlay, but no success.
Working on a nwf file with appended 3D model.
Haw made a 3D Drawing with all other files xrefed in to it and when i save this file manually it updates nawis when refreshing. Earlier it was only to save the file I worked on and when i refreshed Nawis it was updated.
Don't haw the time to experiment so much due to time schedule in project, but continue to try to solve it.
Jon
Employee
TomislavGolubovic
Message 3 of 5 (181 Views)
04-27-2012 04:00 AM in reply to: joneriksen
Have you tried deleting the NWC file and restarting?
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Active Contributor
roryromano
Message 4 of 5 (179 Views)
04-27-2012 05:04 AM in reply to: TomislavGolubovic
Yes, i tried deleting the nwc.
Also tried getting rid of reading and wrting cache all together.
The strange part about this is how one day it was working pefrectly fine, then the next day it stopped...
Rory
Active Contributor
roryromano
Message 5 of 5 (149 Views)
04-30-2012 10:24 AM in reply to: roryromano
Has anyone been able to figure this out yet?
Need a solution ASAP !!
Rory
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
