AutoCAD Plant 3D General DIscussion
New Member
mgoldsmith
Message 1 of 6 (521 Views)
Plant 3D sloped pipe to slip on flange
521 Views, 5 Replies
02-10-2013 03:26 AM
Hi I was just wondering if anyone could help me, we have several cases on site where a sloped pipe goes directly in to a slip on flange. Is there a built in tolerence of how much of a angle the pipe can be before it can be connected direct to the pipe and can this angle be altered?
thanks
Product Support
Dan.Scales
Message 2 of 6 (476 Views)
Re: Plant 3D sloped pipe to slip on flange
02-20-2013 09:29 AM in reply to: mgoldsmith
You can edit the tolerance for your joint in the DefaultConnectorsConfig.xml that is located in the root folder of the project.
This is a section for the connection that you need to edit:
<SlopeTolerance>3</SlopeTolerance>
Dan
Dan Scales
Ahmed1081975
Message 3 of 6 (466 Views)
02-20-2013 10:42 PM in reply to: mgoldsmith
Hi Dan,
I’m sorry to say your answer not sufficient to me please can be more detail with screen snapshot
Ahmed Helal
Product Support
Dan.Scales
Message 4 of 6 (455 Views)
02-21-2013 03:47 AM in reply to: Ahmed1081975
I have attached a screen shot from the DefaultConncetorsConfig.xml below:
You need to edit the SlopeTolerance to the required angle.
Dan
Dan Scales
Ahmed1081975
Message 5 of 6 (449 Views)
02-21-2013 04:00 AM in reply to: Dan.Scales
Thanks For all of you
Ahmed Helal
New Member
mgoldsmith
Message 6 of 6 (445 Views)
02-21-2013 04:15 AM in reply to: Dan.Scales
Hi Dan, I have tried this and I still cannot connect to the flange.
I have a funny feeling though that my project is looking at the wrong DefaultConncetorsConfig.xml file. Is there a way to check if the path to this is correct?
I have changed the tolerance to 5% perhaps this is to much?
Mathew
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
