AutoCAD Plant 3D Forum
Plant 3D sloped pipe to slip on flange
5 REPLIES 5
mgoldsmith
1083 Views, 5 Replies
Hi I was just wondering if anyone could help me, we have several cases on site where a sloped pipe goes directly in to a slip on flange. Is there a built in tolerence of how much of a angle the pipe can be before it can be connected direct to the pipe and can this angle be altered?
thanks
5 REPLIES 5
Dan.Scales
in reply to: mgoldsmith
You can edit the tolerance for your joint in the DefaultConnectorsConfig.xml that is located in the root folder of the project.
This is a section for the connection that you need to edit:
<SlopeTolerance>3</SlopeTolerance>
Dan
Dan Scales
Ahmed1081975
Hi Dan,
I’m sorry to say your answer not sufficient to me please can be more detail with screen snapshot
Ahmed Helal
Dan.Scales
in reply to: Ahmed1081975
I have attached a screen shot from the DefaultConncetorsConfig.xml below:
You need to edit the SlopeTolerance to the required angle.
Dan
Dan Scales
Ahmed1081975
in reply to: Dan.Scales
Thanks For all of you
Ahmed Helal
mgoldsmith
Hi Dan, I have tried this and I still cannot connect to the flange.
I have a funny feeling though that my project is looking at the wrong DefaultConncetorsConfig.xml file. Is there a way to check if the path to this is correct?
I have changed the tolerance to 5% perhaps this is to much?
Mathew
”Boost
