AutoCAD Plant 3D General DIscussion
Valued Mentor
JohnHolder
Message 1 of 3 (169 Views)
Accepted Solution
Plant 3d Reports
169 Views, 2 Replies
04-28-2012 11:55 AM
Major issue with the reports...
In one drawing I have 2 styles of tanks.  2205 model and 2805 model.
Short Discription : Tank
Long Description : Aquacare 2205
Long Description : Aquacare 2805
with the report creator, it would make sense that under the title "Tank"
there would be TWO lines
2Aquacare 2205
4Aquacare 2805
but for some reason ?!?!
6Aquacare 2205
Do I seriously have to have a single short description for EACH and every tank style?
this still applies to reducers and most likely ells aswell...
edit : it seems to if I add a nozzle the tanks are seperated... but these tanks do NOT HAVE NOZZLES.
they have a different long discription.
So it seems like if the short description is the same - they all must be identical?!  even when they have different long descriptions?
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Valued Mentor
ybogdanov
Message 2 of 3 (156 Views)
Re: Plant 3d Reports
04-29-2012 02:12 AM in reply to: JohnHolder
It's bad configuration of grouping. Revise it. In your case the program grouping only with short description, is necessary to add another level of group "Long description".
In the "Edit Layout" down part of screen.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Valued Mentor
JohnHolder
Message 3 of 3 (146 Views)
04-29-2012 07:52 AM in reply to: ybogdanov
Thank you!  I managed to figure out the tanks... now the test is for the reduction bushings to see if that sorts properly.
John.
Master Yoda.
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
