Major issue with the reports...
In one drawing I have 2 styles of tanks. 2205 model and 2805 model.
Short Discription : Tank
Long Description : Aquacare 2205
Long Description : Aquacare 2805
with the report creator, it would make sense that under the title "Tank"
there would be TWO lines
2Aquacare 2205
4Aquacare 2805
but for some reason ?!?!
6Aquacare 2205
Do I seriously have to have a single short description for EACH and every tank style?
this still applies to reducers and most likely ells aswell...
edit : it seems to if I add a nozzle the tanks are seperated... but these tanks do NOT HAVE NOZZLES.
they have a different long discription.
So it seems like if the short description is the same - they all must be identical?! even when they have different long descriptions?
Solved by ybogdanov. Go to Solution.
It's bad configuration of grouping. Revise it. In your case the program grouping only with short description, is necessary to add another level of group "Long description".
In the "Edit Layout" down part of screen.
Thank you! I managed to figure out the tanks... now the test is for the reduction bushings to see if that sorts properly.
John.
