AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant 3D for plumbing waste lines - good idea?
3 REPLIES 3
mdsonline
534 Views, 3 Replies
Our firm is currently using both Acad MEP & (have recently gone) to Plant 3D.  My question is which program is better for drawing (plumbing) waste lines (wyes, traps, cleanouts, etc..)?   My engineer wants me to use Plant for the plumbing piping,  I think we should use MEP.  So I want to "Ask the Experts" - from experience which is the better program to use for wastelines?
3 REPLIES 3
in reply to: mdsonline
Can't see why you want to use Plant for that.  You will have a lot of work to setup catalogues and the outputs are isometrics, which are unusual for plumbing work.  If you need the iso's for some reason, then plant is going to produce them, but otherwise MEP would be better.
cadwomen
http://autocad.autodesk.com/?nd=plant_ask_the_expert
cu cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
dave.wolfe
in reply to: cadwomen
I vote for MEP. Same reasons as given above.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
