When we open .dwg files from Plant 3D 2013 in Navisworks Manage 2013 equipment will NOT show up as shaded (see example-01.jpg) even though we have changed the Navisworks option for Rendering of .dwg files to be "Shaded" (see example-02.jpg?
Has anyone else run accross this? Any suggestions would be appreciated!
Thanks!
I'm facing the same problem as well.. It just happened when i turn on my navisworks this morning. I tried to open other files it also the same. And not only the Equipments. The elbow of the pipelines also turn into wireframe.
I have solved my issue with the wireframe equipment and elbow. It is done by uninstal and reinstall the object enabler of plant 3d. But uninstalling cannot be done from Remove Program in control panel. Must use uninstall from the object enabler uninstaller.
