AutoCAD Plant 3D General DIscussion
New Member
MMarzolf
Message 1 of 3 (1,196 Views)
Plant 3D Custom Parts
1196 Views, 2 Replies
01-15-2013 06:44 AM
The end goal is to have the rest of my office be able to pipe to and from the inline parts I model in Inventor in Plant 3D.
I have discussed this issue with an outside company we use to troubleshoot our Autodesk issues and they have not been very helpful.  All they have told me is that my theory/ logic/ process/ whathaveyou sounds correct and they will look into it further.  I think the problem is where I am saving certain files and cant seem to figure out the right combinaiton of locations that will allow me to save a catalog on the server for others to access.
I start with making an inventor part and saving the .ipt on the server under a folder of custom parts. I then Export the file as a .dwg and save it under the AutoCad Plant3d Content folder on my C/: drive so it can be opened in Plant.  I open the .dwg of the custom part in Plant and save it as a block with the same title and run PLANTPARTCONVERT to designate my ports.
This next step is where I feel like I'm messing up:
I go to the catalog builder and select new catalog.  I copy one of the stock catalogs that comes with Plant, remove all of the existing parts, and save it as the brand of valve I want to make the catalog.  I put in all of the parts, designate the port sizes and end connection types. The folder where I saved the exported .dwg, catalog,  and other files looks like this:
The last step I take is cpoying the above files to the folder on the server where I saved the inventor parts just to keep everything together.  I open the catalog that is now saved on the server and add it to the spec that everyone uses in Plant, which is updated per job.  The spec works fine for me.  I can pipe to and from the valves I make, but no one else is able to.  When they reload the spec, the name of the valve comes up in the palate, but instead of a preview of the object next to it, there is just a white box.
Lastly, there is a folder called 200 and DWG that I find with the standard catalog files.  But I cant seem to find it when I make my own.
Its (for me at least) a pretty complicated process.  Has anyone else encountered something like this?
Valued Contributor
batone79
Message 2 of 3 (1,185 Views)
Re: Plant 3D Custom Parts
01-15-2013 10:17 AM in reply to: MMarzolf
Each Draftsman or Designer need to have a copy of your Autocad Plant 3D 2013 Content Folder in their same folder in C:
 done!
Active Contributor
rchiasson
Message 3 of 3 (1,158 Views)
01-16-2013 08:36 AM in reply to: MMarzolf
Do you have everyone's Spec Editor's pathed to the network AutoCAD Plant 3D 1013 Content folder? If you go to Tools>Modify Shared Content Folder, there is a path that needs to be directed to the server. I'm guessing that it is working on your machine because you still have the custom content locally.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
