AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant 3D Continuation Grip Problem
1 REPLY 1
600 Views, 1 Reply
I don’t know if anyone else has had this problem before but the Continuation grips are still showing up on my pipe and fittings after I have routed to them. When you try to continue pipe from these grips an error message saying "Cannot Find Suitable branch in branch table". This effecting all of the specs I have in plant 3d including both custom specs and the specs that came with Plant3D. It also effecting all of the projects that I try to work on in plant 3D. I can still model pipe but I would like to know why they have suddenly appeared out of know where?????
1 REPLY 1
quentin.contreras
If this is showing for all current and new projects, then you might want to try a repair for Plant 3D. Go to windows control panel, unistall programs, select Plant 3D. This will give you the Plant 3D uninstall window and you will want to select Repair/Reinstall. Try the repair first, if that does not help, then try the reinstall to see if this resolves the issue for you.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
”Boost
