AutoCAD Plant 3D General DIscussion
2 Kudos
Post 1 of 9
Plant 3d and ASD cannot cooperate seamlessly?
1186 Views, 8 Replies
12-18-2011 08:51 PM
I use Plant Design Suite. I make steel structure in ASD, then xref it in Plant 3D. Problems is:
1.After Object Enabler installed, ASD models display  detailed(show all roundings etc). This reduce the progame performace seriously. No tools can control it in Plant 3D. Settings in ASD PREFERENCES doesn't affect it either.
2.With regard to ASD models, Osnap cann't work in Plant 3D like that in ASD. I cannot snap almost all contour vetex or midpoint. This makes assembling with other objects in Plant 3D so difficult.
3. When generate Otho drawing of models including ASD models, the result is so bad.(So useless detailed lines).
Any ideas helpful? Thanks!
Product Support
55 Kudos
Post 2 of 9
Re: Plant 3d and ASD cannot cooperate seamlessly?
01-04-2012 12:06 PM in reply to: followsea
I will check with the development team on these issues and give you an update as soon as possible.
Thank you,
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Product Support
55 Kudos
Post 3 of 9
01-25-2012 07:40 AM in reply to: followsea
The object enablers for AutoCAD Structural Detailing have recently been updated. Please download, install and let us know the results:
AutoCAD Structural Detailing 2012 Object Enablers (32-bit and 64-bit)
Thank you,
Jason Drew
Product Support
2 Kudos
Post 4 of 9
02-15-2012 07:21 PM in reply to: jason.drew
Only resolve the display(Detailing or without roudings, configured in ASD) when you directly open the ASD file in P3D. But when XREF it in P3D, it display detailing, regardless of the configuration.
All other problem  exist.
Another improving is good. P3D can XREF ASD formworks model now, while it always collapse before. But another problem arise: the axis number dissaper when xref it in P3D.
Thanks.
Member
0 Kudos
Post 5 of 9
02-18-2012 04:50 PM in reply to: followsea
may be the intelligent SDNF import interface for AutoCAD PLANT 3D is an opportunity for you? Get in contact with Unitec.de for further details.
Distinguished Contributor
54 Kudos
Post 6 of 9
07-11-2012 08:48 AM in reply to: kmayland
The same issue we are facing now?
How Autodesk didn't answer this question for more than a year?
54 Kudos
Post 7 of 9
07-12-2012 12:09 AM in reply to: followsea
Looking for prompt answer from Autodesk in this regard.
Product Support
55 Kudos
Post 8 of 9
02-06-2013 08:39 AM in reply to: followsea
One workaround that has been suggested to me is using "Save model to ACIS solids" from ASD:
This will save the ASD model to a .DWG which can be copied into Plant 3D and attached as an XREF. Object snaps will work and all connection detail (plates/bolts/etc.) will display in the model and on the orthographic views.
Jason Drew
Product Support
0 Kudos
Post 9 of 9
02-18-2014 11:17 PM in reply to: followsea
Hi Jason Drew,
If we save this as ACIS Solid then the intelligent will loose, so is there a update or hotfix available now?
-Saravanan
Saravanan
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
