AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
PLANT 3D 2014 ORTHO LAYERS
2 REPLIES 2
Dolan.Raynor
730 Views, 2 Replies
I am new to Plant 3d and I am having difficulty with colours in my ortho drawings. I have created a company template to use, but I cannot make the use 3d model option. If I select the check box and close out it does not save this so next time I go back in it is not checked.
2 REPLIES 2
phwatso
in reply to: Dolan.Raynor
There should be a folder called Orthos in the project directory structure containing 3 more folders called DWGs, Orthocube Library and Styles. The Styles folder is where the ortho settings get saved. There was a bug and this folder setup didn't get created correctly...
Dolan.Raynor
in reply to: phwatso
Thanks for the reply. I created a new dummy project and replaced my ortho folder with the new projects'. This now works great. Thanks again for the response and solution.
”Boost
