AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant 3D 2014 Nominal Spec not showing
3 REPLIES 3
jtegtmeyer
821 Views, 3 Replies
Does anyone else have the issue with the spec not populating the isometric boder when linking to the attribute or placing the spec attribute in the border?
Thanks for the feedback!
Teg
Tags (1)
3 REPLIES 3
That “NominalSpec” attribute can be confusing. It is not necessarily the actual spec being used, but a P3d LineGroup property that needs to be manually assigned. This value can be populated using a Tag in P3d Line Group to prompt input for this information. See this video for clarification:  http://screencast.com/t/gZDCzQrEES
(If this answers your question, please mark it as an Accepted Solution.)
Martin Stewart
AEC Support Specialist
Martin,
What I’m looking for is the spec type/nominal spec to fill in the field in the isometric title block. I tested it on the sample project and it also doesn’t work or populate the field.
If I’m following you correctly, I don’t think this is currently possible to make the Spec a title block property for an Iso. This would be because there can often be more than one spec used per line number.  In those cases, not sure how programmatically they would determine which of the specs the customer wants listed.  So the video provided earlier is one work-around. Perhaps another is to use the LDT feature for this.
To configure an isometric line designation table:
http://docs.autodesk.com/PLNT3D/2014/ENU/filesPLNT3D/GUID-E010FC58-77DF-44B5-923A-8898CF4566E6.htm
Also, please feel free to make product enhancement recommendations at this link: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Martin Stewart
”Boost
