Hi there,
Plant 3D 2013 opened files created through Plant 3D 2014 with some items missing.
Please indicate if the spec need to be migrated or something else happened.
Solved by martinTstewart_Adsk. Go to Solution.
Plant 3D is not backwards compatible with previous releases. You migrate forward to 2014, but once a project is in 2014, it is no longer compatible with 2013.
(If this answers your question, please mark it as an Accepted Solution.)
