AutoCAD Plant 3D Forum
Plant 3D 2013 Isometric Output
4 REPLIES 4
1431 Views, 4 Replies
I've started using Plant 3D 2013 and have a few questions.  (See attachment).
  1. Highlighted in pink, these dimensions are a bit odd.  Plant 2012 never dimensioned in this way and was  just wondering if the dimension could go all the way to the IP point rather than the weld lines.
  2. I have a pipe support which has a tag number but for some reason the tag is not appearing on the iso.
  3. The annotations circled.  Is there a way to remove these from the isometric.  Maybe in the xml file.
  4. The annotations clouded.  Again, can these be removed from the iso.  It just clutters the iso with unnecessary and repeat information.
Thanks all.
Jason
4 REPLIES 4
Ahmed1081975
I have Also Isometric output please refre the attached snapshot
We need help
Ahmed Helal
Hi all,
Well I have managed to figure out how to get points 2, 3 and 4 to work.  All done through the isoconfig.xml file.
Still having problems though with the first point.  It's strange because 2012 worked perfectly.
Cheers,
Ahmed1081975
Hi All,
Another One proplen in dimension Settings For Isometric please Rfer to Screen shot
Ahmed Helal
richard.imrie
Hi there,
I realise this is a bit late as your posts were roughly a year ago, however i was wondering if you could advise me on how you got point 4 to remove from the iso, specifically the line size text that is arrowed to the line, In your example the 10" text. Most annoying.
”Boost
