The first important thing is "Editor of ISO symbols"!!! And Plant Report Creator, with this program is not necessary use Access to generate reports.
And the most important thing, now we can create the pipes and fasteners in the Spec Editor!!!
@karoljd wrote:You are welcome!
If you manage, please post changes that you see in this release. I'm away for some time from my Office and on mobile Internet so I can't test the P3D.
Ok, got mine, was delivered this morning, its loaded, now I'm trying to see what's new.
not much so far, do NOTsee Iso Skey editor, only a Report Creator.
A bit disappointed, just a disc in a cover with new graphic, no "whats new" to see what changed.
The search continues.....
@Stevee420 wrote:Ok, got mine, was delivered this morning, its loaded, now I'm trying to see what's new.
Iso symbol editor there is in Project Setup
I found that editor, but how do you assign new symbol to new custom valves, so thay show correcrly in the iso's?
I dont think these are the SKEYS symbols.
for example if I assign VYBW as a SKEY to a new created componant, it does not show up in iso
In the catalog editor, pick...Use Plant 3d Parametric Graphics...Fittings....Sleeve...BV
now scroll all the way to right in geometry window........Pipe/Pipe(pe)
found it by accident....nice place for the autodesk team to hide them!
It would be nice for autodesk to supply us the "Important Subscription Users" all the required documentation telling us whats new instead of leaving us in the dark.
Can anyone answer me this question (not installed P3D 2012 yet, have disk on my desk) does the help go to a new 2012 location or the old 2011 location?
@Anonymous wrote:It would be nice for autodesk to supply us the "Important Subscription Users" all the required documentation telling us whats new instead of leaving us in the dark.
New.
But in the Custom Geometry for the new component the Pipe and fasteners there aren't yet... We can't to create square pipe (to use like cable-tray) and new tri-clamp connections...
In this release of the Plant3D the ISO part has many good changes. This is the most diference with 2011. For example, good interface to edit ISO template.
I hope that in the 2013 there are some part for instrument and electrical devices.
Hi everyone,
Some may have noticed the fact can not be removed nozzles from the equipment, when delete nozzle also we delete for example tank, remove is working in AutoCAD PLANT 3D 2011, maybe it is some other way
Thank for you help
@Anonymous wrote:Hi everyone,
Thank for you help
To select Nozzle you need to press Ctrl and then select. Remember that the same method is used to select gaskets and bolt sets.
