AutoCAD Plant 3D General DIscussion
Valued Contributor
6 Kudos
Post 1 of 4
Placing supports
94 Views, 3 Replies
03-22-2012 08:12 AM
Dynamic Input works fine when placing valve, but not when placing a support. The Dynamic Input is from the base point (0,0,0), not from the nearest fitting or pipe intersection. Support has to manually be moved to location desired. If moving the support after insertion, the Dynamic Input is from the insertion point of the support. Is this a bug or a settings? I can't find anything that addresses this problem.
Sunetic Services
Owner/Consultant
Employee
51 Kudos
Post 2 of 4
Re: Placing supports
03-22-2012 05:49 PM in reply to: Grampster
There is a way to place a support dynamically from a particular basepoint. I just have to write it down. You start with placing the support, then telling it the base point is from another point. If its not already on the forums, I'll post it up.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
Valued Contributor
6 Kudos
Post 3 of 4
03-22-2012 06:42 PM in reply to: Grampster
Okay, so the problem is with AP3D, confirming what I thought. I'll discuss the situation at a conference next month. I have three work-arounds. The first is to draw a simple ACAD line from one of the pipe nodes and offset it to where you want the support to be, and then erase the ACAD lines after the support is placed. The other isn't much better. Do an ID at a base point (i.e.structural grid) and write the value down. That will be based on 0,0,0. A quick calc will give you the exact X or Y for the support (the pipe will determine the other coordinates). Then use the Dynamic Input. The last is to do a Distance from the support node to where you want the support to be, and then move it X or Y in that direction. They're clunky, but they work for now until support placement method is fixed. I'm sure there are other ways.
Once a support is placed, say on a rack grid, it can be copied or arrayed like any other ACAD component. The user needs to keep in mind that, unlike valves or fittings, the type of support can't be substituted after placement.
Sunetic Services
Owner/Consultant
Employee
51 Kudos
Post 4 of 4
03-23-2012 05:39 PM in reply to: Grampster
A colleague sent me this a while back, placing supports in a known position from another fitting:
  1. Select the pipe support from the tool palette and place it somewhere in the pipe using a Nearest snap.
  2. Select the placed support and click on the move grip and move it off the pipe.
  3. Click on the move grip again to move it back to the pipe at the precise location. Key in FROM, specify a base point such as end of the pipe.
  4. Key in the distance value while the snap to the pipe in the Nearest mode. Object snap mode of Nearest on the pipe should be visible for the support to be accurately placed by the keyed distance on the pipe.
  5. Use DIST command to verify the distance.
Let me know if this works for you.
Tomislav Golubovic
Autodesk, Inc.
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
