AutoCAD Plant 3D General DIscussion
Valued Mentor
tmccar
Message 1 of 3 (269 Views)
Place custom olet
269 Views, 2 Replies
02-02-2013 12:59 AM
I have created a custom olet which has a compression fitting but when I try to place it on the pipe, it snaps to the second port (the fitting port) rather than the centre of the olet radius. It will not straddle the pipe but sits at 90° to it. How can I prevent this from happening?
Tom
Active Contributor
rchiasson
Message 2 of 3 (216 Views)
Re: Place custom olet
02-04-2013 05:32 AM in reply to: tmccar
I a little confused on how your component is created. Is the compression fitting a seperate component from the olet? Or did you create a custom olet and it keeps placing at the end of the pipe?
I tried placing a stadard olet and couldn't get it to place any way but perpendicular to the pipe. I will have to try building one and seeing how it places when I get some time. Some pictures and a clearer idea of the process and steps of what you are doing would help.
Valued Mentor
tmccar
Message 3 of 3 (212 Views)
02-04-2013 10:01 AM in reply to: rchiasson
Yes, it's an assembly of a compression fitting and a section of pipe (see attached)
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
