Hey!
I will create an ISO but my Plant 3d shows me the follow message. I have only used one flange from my own spec
Need fast help!
Solved by Ruffy85. Go to Solution.
Check the paths in the ISOGEN.FLS file in the \Isogen\Final directory of your project. You may have moved your project and the path is hardcoded to a path that doesn't exist.
If this isn't it, can you post the message file from Isogen - it often has hints.
Also, can you run other lines in this project without a problem?
Find and older Thread with the same error + Solution. Thanks!
Sorry for so late Answer
Of course here is the link!
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Error-48-Unknown-Error-in-PISOGEN/m-p/2843260
