When trying to apply 1 degree of slope to a pipe i get the message:
"The new settings exceed slope angles defined in project settings and may cause pipes to disconnect. Do you want to apply the slope settings anyway?"
If I say "Yes" the pipes DO disconnect at elbow. Where can I find the setting in the project. If the message is on the right track, then it should be a question of changing the setting.
Regards
Arne Jakobsen
Yes, definately seems like the setting I was after. However: it was set to 5 °, and I was trying to apply 1 ° of slope. I tried to change it to 10 degrees (even 45 degrees) and I still got the same message box.
So I'm wondering what is wrong.
