AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Piping Service Code
3 REPLIES 3
maxpiper
1320 Views, 3 Replies
Piping Service Code
How do I set the service code on a line prior to running the 3D pipe? I am using Plant 3D 2012.
3 REPLIES 3
In the ribbon, when you click on the pulldown marked "Route New Line" if you have the Service setup in the Line Code, then you can input the service there. If not, then run the line, right click on it, and set it in the properties.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
Thanks for your reply. Can you explain how to set up Service in the Line Code under "Route New Line"?
jason.drew
in reply to: maxpiper
Hi John,
In reply to Tom's suggestion, here is some additioal information on the line group tags.
Configuring the service for the pipe run prior to routing would require a line number tag configuration in Project Setup similar to this:
Which allows the service to be set before routing the pipe:
Thank you,
Jason Drew
Designated Support Specialist
”Boost
