AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Piping Isometric Error
11 REPLIES 11
Message 1 of 12
phwatso
4448 Views, 11 Replies
We regularly get this error message when trying to create piping isometrics
1 Isometric(s) were not able to be created:
V:\Jobs & Enquiries\C2400 - Oldham Sewage Treatment - UU\06 PLANT 3D\C2400 Oldham WWTW - UU\Isometric\CEL_A2\PCFs\UserDefinedLine.pcf
There was an error reading from the pipe: Unrecognized error 109 (0x6d).
This seems to only happen on "busy" pipelines.  We get around it by using quickiso to select part of the line but this is a very unsatisfactory solution as they do not appear in the project listing and have to be manually numbered and cross referenced.
See attached PCF file.
11 REPLIES 11
Message 2 of 12
Dan.Scales
in reply to: phwatso
Could you upload a copy of the log file?
Dan
Dan Scales
Message 3 of 12
phwatso
in reply to: Dan.Scales
HI Dan,
See attached PCF and log file.
Message 4 of 12
phwatso
Hi Dan,
Any idea what is causing this problem?
Message 5 of 12
Venkatesan.A
I guess  this is because of the data catche.
Sometimes if you create isometrics for the same line "N" number of times the data doesnt gets overridden causing such error.
Can you please try to clean up your isometric folder (Quick / Prod folder) which ever you are trying to create and try generating the iso.
I tried ur pcf in my machine and it doesnt throw this error (Refer attachement 1 and  2).
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 6 of 12
phwatso
in reply to: Venkatesan.A
HI, just tried the isometrics again, same error. As a rule we always clear the folders out before running isometrics as we have experienced the data not getting overwritten before.
I noticed your run only took 1 minute, mine took 10 minutes on a 64-bit 3.1 GHz Quad core PC with 8GB RAM also we are using Plant 3D 2013 it looked as though you ran it on 2012?
Also Dan Scales said he experienced the same error when running the PCF file...
Iso Creation start time : 09/10/2012 10:54:12
Iso Creation finish time: 09/10/2012 11:04:17
Duration                : 00:10:05
Output folder           : V:\Jobs & Enquiries\C2400 - Oldham Sewage Treatment - UU\06 PLANT 3D\C2400 Oldham WWTW - UU\Isometric\Check_A2\ProdIsos\Drawings
V:\Jobs & Enquiries\C2400 - Oldham Sewage Treatment - UU\06 PLANT 3D\C2400 Oldham WWTW - UU\Isometric\CEL_A2\PCFs\0026.pcf
Message 7 of 12
Venkatesan.A
Yes my apologies.
Just had a chat with Dan, even i could repro it in 2013, i guess there is some issue generating in 2013.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 8 of 12
robbyjb
Has this issue been resolved ?
I am having the same problem, aswell as "FAILURE - Source array was not long enough. Check srcIndex and length, and the array's lower bounds"
Any assistance would be appreciated.
Message 9 of 12
phwatso
in reply to: robbyjb
Haven't seen a solution other than break the pipline down into smaller sections 😞
Message 10 of 12
Venkatesan.A
We have reported this to our developers and they are looking into it.
We suspect it could be because of the ISO engine time out, where it gets into a continuous loop.
We did find that in some cases inserting a break point manually solves the problem.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 11 of 12
robbyjb
Thanks for the replies.
I have broken the line into smaller sections as recommended, and am able to generate the iso's.
I guess it would help if more information was given when errors are encountered, so you know where
to start looking. Smiley Happy
Message 12 of 12
Arun_Kumar_K
Gone through the PCF, I can see weld display has been assigned in this case. Could you switch-off the weld display in project properties, and connect all the lines again. You should ensure no weld display in the pipe line in 3d. You will get now. I find problem like this only when I draw line with weld display.
”Boost
