AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Piping Connection Settings Not Showing up
2 REPLIES 2
TRdesigner82
527 Views, 2 Replies
We have a newer employee that is just starting to use Plant3D. When he opens the same project as the rest of us, or even the training project, he has no piping connections set up. Shouldn't this come from the DefaultConnectorsConfig.xml? This is a SQL project and we are all pulling from a network project so we're all looking at the same files. Why would he not have these connections but everyone else does? This is in 2014 and his SharedContentFolder is set properly to the same as the rest of us. Any ideas???
2 REPLIES 2
TRdesigner82
in reply to: TRdesigner82
We did a re-install and it seems to work as it should now.
mikeshr2
Most of the time doing step 1 described here
http://forums.autodesk.com/autodesk/board/message?board.id=371&message.id=12491#M12491
by Gersteb saves time that it takes to reinstall.
”Boost
