AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Pipes and fittings?
1 REPLY 1
cisrael
460 Views, 1 Reply
Pipes and fittings?
Quick questions.
What is the maximum diameter of pipe and fittings in the libraries for this program?
Are the ductile iron fittings in the libraries AWWA standard fittings?
Is there a library for mechanical joint fittings?
1 REPLY 1
LoriWu
in reply to: cisrael
For the joint settings, you can make some settings in project setup.
Project Setup->Connections->Joint Settings, please have a try.
”Boost
