AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Pipeline Tagging Issue
1 REPLY 1
eskisa0100
559 Views, 1 Reply
I have P&ID's with the same line numbers that I will be hopefully connecting soon.  I had to change the pipe line tag order and the spec. callout in the middle of this project because my company decided they wanted it to be different than the default orientation.  My problem is, whenever I go into a line and try to change the spec from let's say CS150 to 150, it comes up with the attached message.  Isn't this the point of the off page connectors and smart P&ID's?  That you CAN have pipes with the same tag.  I mean how do you run pipes from sheet to sheet if you can't have the same line number?
Please help!
thank you,
eskisa0100
1 REPLY 1
patpat79
in reply to: eskisa0100
In 2013 version, i dont know if still works on 2014, just untag the other line which you will connect, then try to connect the tagged line to the untagged. Just make sure that the line that you will be connecting is the tagged one or else, both will have no tags.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
”Boost
