AutoCAD Plant 3D Forum
Pipe Weld Joint Symbol in Ortho Drawing
6 REPLIES 6
rigginc
1287 Views, 6 Replies
Does anyone know if there is a way to have a standard symbol auto-inserted at each field weld location on an Ortho Drawing?
6 REPLIES 6
jason.drew
in reply to: rigginc
Are you looking for weld numbers similar to the Isometric drawings?
Jason Drew
Designated Support Specialist
rigginc
in reply to: jason.drew
I am looking to have a symbol show up so that we can clearly see the location of a field weld.  Currently there is just a line which is hard to see unless the scale is large enough.
jason.drew
Are you using Plant 3D 2011 or Plant 3D 2012?
Thank you,
Jason Drew
rigginc
Plant 3D 2012.
jason.drew
Thank you for the reply back. I will pass this along to the team as a feature request for 2012.
With regard,
Jason Drew
Hi Jason
I would like to ask you whether this problem has been resolved? I would also need the option to show welds in orthographic drawings similarly to the weld dots in isometrics.
Thank you.
With regard,
Lukas
”Boost
