AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
M-BRF
468 Views, 1 Reply
pipe tag
I created a style tag for P & ID (IMAGE TAG.PNG)
I have the following questions or preblemas:
1 - to draw the LINE NUMBER pipes SELECTOR are not the line number you have designated in the P & ID (image tag2.png)
I have to do to be in tag number selector?
2-to try to put the pipe tag I get the following message 'NO TAG FORMAT AVAILABLE FOR THIS COMPONENT' (image tag3.png)
I have to do to let me put the tag on the pipes that I have drawn in 3d
that's what I have to do? I've done wrong?
thanks
he creado un estilo de tag para los P&ID ( IMAGEN TAG.PNG)
tengo las siguientes dudas o preblemas:
1- al dibujar tuberias en el LINE NUMBER SELECTOR no estan los numero de linea que he designado en el P&ID (imagen tag2.png)
que he de hacer para que esten en tag number selector?
2-al intentar poner tag a la tuberia me sale el siguiente el mensaje ' NO TAG FORMAT AVAILABLE FOR THIS COMPONENT'
que tengo que hacer para que me deje poner el tag a las tuberias que tengo dibujadas en 3d
que es lo que tengo que hacer? que he hecho mal?
gracias
1 REPLY 1
Dan.Scales
in reply to: M-BRF
Your P&ID tag looks OK to me. I set one up the same you and the P&ID lines numbers show without problem in the list.
What tag format have you set for the P3d pipes?
Dan
Dan Scales
”Boost
