AutoCAD Plant 3D General DIscussion
New Member
Stefan_WSP
Message 1 of 2 (271 Views)
Pipe Support problem with sloped pipes P3D 2013
271 Views, 1 Replies
01-21-2013 12:13 AM
The pipe supports do not rotate and align to the pipe when I have a Sloped Pipe. Is it possible to change any settings in the program to make the pipe supports align with the pipe slope?
Active Member
Sap_joakim
Message 2 of 2 (199 Views)
Re: Pipe Support problem with sloped pipes P3D 2013
01-28-2013 10:34 PM in reply to: Stefan_WSP
I have the same problems. But you can rotate the support after attaching it to a pipe. this is what i have been doing on my sloep pipes. after you have rotated a support you just copy that one to youre next location using array with slope after pipe. remember to use Reference when you rotate the support sp you get it exactly right on the pipe :smileyhappy:
Good Luck
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
