AutoCAD Plant 3D Forum
Pipe Support Issues
5 REPLIES 5
thebearjed
636 Views, 5 Replies
Pipe Support Issues
As shown in the first attachment (PipeSupports3D) i get an error when trying to place a pipe support from the Pipe Supports Palette. Also why do i have 2 pipe dupport tabs, the other being Pipe Support Spec?
I was able to place a shoe using the Pipe Support Spec Palette but as seen in the second attachment (IsoShoeExample) i get a spec break on my iso...and what are the break marks shown on this iso for?
5 REPLIES 5
thebearjed
in reply to: thebearjed
Anyone?
thebearjed
knock...knock...
I'd look at doing a repair/reinstall, thats definitely not right. Has anyone been trying to customise the cui file or palettes?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
i managed to get rid of the palette but the other issues are still outstanding.
doing a reinstall is a last resort, not a fix. i don't want to have to set everything back up.
neonade
You could test logging in your pc using a different or created user.
If plant 3d works fine on other users then maybe the setting on your user end is corrupted.
”Boost
