AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Pipe Support Details
2 REPLIES 2
kaiser6977
719 Views, 2 Replies
Is it possible to extract pipe support drawings or details from the supports entered in the model?
2 REPLIES 2
gulnacm
in reply to: kaiser6977
You can use the ortho function to generate the different views of supports, use the the annotation function to right the tagging, description, or any other data entries and use the autocad dimensioning functions to dimention.
Mike G (Autodesk)
Michael Gulnac
Technical Specialist
Organization
Autodesk, Inc.
in reply to: gulnacm
Individually dimension every pipe support in a model?  All 10,000 of them?  Hmm... I think not.
What we need to get is a database dump of the pipe support dimensions that are displayed in the properties.  Then we just check type vs standard drawing for said type, vs the dimensions in properties, and the allowed dimensions in the standard drawing...
You know... standard drafting practice and all...
”Boost
