Is there a way to refresh or clean out the dimensional spec update tool palette after you update parts? I want to see what items have been updated from the spec and the only way I have figured out to see a clean version of the dimensional spec update is to change the spec and re-run the process.
Here is my issue:
When I do a spec update check without changing anything. P3D says there are no updates to be made. Yet when I do change a single fitting in the spec. Then do a spec update it repopulates the dialog with data I have changed the fitting and also with data that was changed the first time it was put in ie. a valve. So I then pick those two items to update I assume they get updated. I try to spec update check and P3D says no updates. So I then change another item and do a refresh. The dialog populates with the changed item and the same valve that was on there previously. How do I get that dialog to refresh without changing the spec or how do I get the valve to update and get removed from the list?
Ben
