AutoCAD Plant 3D General DIscussion
Valued Contributor
arjan.gorinsekéman-engineering.be
Message 1 of 12 (1,215 Views)
Pipe spec HDPE 100
1215 Views, 11 Replies
02-17-2010 06:27 AM
is there a pipe spec for HDPE 100 sdr11,sdr17
Employee
gulnacm
Message 2 of 12 (1,215 Views)
Re: Pipe spec HDPE 100
02-18-2010 11:13 AM in reply to: arjan.gorinsekéman-engineering.be
currently we do not have HDPE content included with this release. This is something that Autodesk is actively pursuing to add various content and to include tools that will allow users to create missing content and information.
Michael Gulnac
Technical Specialist
Organization
New Member
joshwithmarsau
Message 3 of 12 (1,062 Views)
08-09-2011 11:32 AM in reply to: arjan.gorinsekéman-engineering.be
has there been any update on this?
Valued Mentor
Rich.O.3d
Message 4 of 12 (1,055 Views)
08-09-2011 02:58 PM in reply to: joshwithmarsau
there are PE100 parts in the australian pipes & fittings catalogue version 3
you can download it from here:
http://autocad.autodesk.com/?nd=plant_content_packs
Good start for creating your own supplier based cats.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Active Member
raulingeniero79
Message 5 of 12 (925 Views)
12-09-2011 01:52 PM in reply to: arjan.gorinsekéman-engineering.be
Hi, where can I find HDPE spec for Plant 3D 2012 (DIN 16963)?
Employee
TomislavGolubovic
Message 6 of 12 (915 Views)
12-10-2011 09:54 PM in reply to: raulingeniero79
Did you check the Plant Exchange website and look under Content Packs?
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Active Contributor
PLANToftheAPES
Message 7 of 12 (904 Views)
12-12-2011 09:07 AM in reply to: arjan.gorinsekéman-engineering.be
So, to ask the obvious, is there an HDPE spec for English and imperial units that comes with Plant 3D 2012?
New Member
joego27
Message 8 of 12 (881 Views)
12-14-2011 02:45 PM in reply to: arjan.gorinsekéman-engineering.be
No HDPE for the Imper. and its not easy to build a catalog or spec for that.:manmad:
Active Member
emaloney
Message 9 of 12 (127 Views)
08-27-2014 10:56 AM in reply to: arjan.gorinsekéman-engineering.be
Does anyone know if there is an HDPE content pack/pipe spec that will work with Plant 3D 2014??
MuddyPipe
Message 10 of 12 (112 Views)
08-27-2014 06:41 PM in reply to: emaloney
I have been using the pipe content from ISCO. I modified that for Ferguson.
It is not bad except the fitting connection used fusion weld. I have to play around the setting to get it to work.
Have to be careful with their dimensions, ISCO dimensions always bigger than Ferguson.
I got complains from Installer for wrong fittings.
What they don't say is they substitute the fitting with ISCO.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
