AutoCAD Plant 3D Forum
Pipe spec HDPE 100
12 REPLIES 12
Message 1 of 13
7839 Views, 12 Replies
Pipe spec HDPE 100
is there a pipe spec for HDPE 100 sdr11,sdr17
Tags (1)
12 REPLIES 12
Message 2 of 13
gulnacm
currently we do not have HDPE content included with this release. This is something that Autodesk is actively pursuing to add various content and to include tools that will allow users to create missing content and information.
Michael Gulnac
Technical Specialist
Organization
Autodesk, Inc.
Message 3 of 13
joshwithmarsau
has there been any update on this?
Message 4 of 13
in reply to: joshwithmarsau
there are PE100 parts in the australian pipes & fittings catalogue version 3
you can download it from here:
http://autocad.autodesk.com/?nd=plant_content_packs
Good start for creating your own supplier based cats.
Message 5 of 13
Hi, where can I find HDPE spec for Plant 3D 2012 (DIN 16963)?
Message 6 of 13
TomislavGolubovic
Did you check the Plant Exchange website and look under Content Packs?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 7 of 13
So, to ask the obvious, is there an HDPE spec for English and imperial units that comes with Plant 3D 2012?
Message 8 of 13
joego27
No HDPE for the Imper. and its not easy to build a catalog or spec for that.Man Mad
Message 9 of 13
emaloney
Does anyone know if there is an HDPE content pack/pipe spec that will work with Plant 3D 2014??
Message 10 of 13
in reply to: emaloney
I have been using the pipe content from ISCO. I modified that for Ferguson.
It is not bad except the fitting connection used fusion weld. I have to play around the setting to get it to work.
Have to be careful with their dimensions, ISCO dimensions always bigger than Ferguson.
I got complains from Installer for wrong fittings.
What they don't say is they substitute the fitting with ISCO.
Message 11 of 13
Ahmed1081975
yes
the ontent Name is  ( AGRULINE_Pipes_and_Fittings_Catalog.pca )
Ahmed Helal
Message 12 of 13
Ahmed1081975
PLS, find the attched file for the Contanet PAck MAnual ,
( AGRULINE_Pipes_and_Fittings_Catalog )
Ahmed Helal
Message 13 of 13
free2aja
in reply to: Ahmed1081975
I need help .... I used AGRU catalog and have changed it into a spec, how to modify it so that it can be connected with equipment (steel) or with other spec ... And why part use priority 'error. How to change it or modify it? thanks for your fast respon
”Boost
