there are PE100 parts in the australian pipes & fittings catalogue version 3
you can download it from here:
http://autocad.autodesk.com/?nd=plant_content_packs
Good start for creating your own supplier based cats.
Did you check the Plant Exchange website and look under Content Packs?
So, to ask the obvious, is there an HDPE spec for English and imperial units that comes with Plant 3D 2012?
No HDPE for the Imper. and its not easy to build a catalog or spec for that.
Does anyone know if there is an HDPE content pack/pipe spec that will work with Plant 3D 2014??
yes
the ontent Name is ( AGRULINE_Pipes_and_Fittings_Catalog.pca )
Ahmed Helal
PLS, find the attched file for the Contanet PAck MAnual ,
( AGRULINE_Pipes_and_Fittings_Catalog )
Ahmed Helal
