AutoCAD Plant 3D General DIscussion
Valued Contributor
blorich
Message 1 of 4 (287 Views)
Pipe Segments
287 Views, 3 Replies
11-29-2012 12:48 PM
This might be a wish list item but I would like to be able to set the pipe segments length to 0.  That way when I add weldneck flange to an elbow it doesn't need to insert a pipe length.  I know I can manuly add this, but when designing it would be nice to be able to place a flanged valve on an eblow and have the autopipe not include a pipe segment.  I don't see why you need to put a number in there (minimum being .25" it tells me) since you can take a socketweld flange and place it on an elbow with out a spool, its not recommended but it can be done, ask a pipe fitter.
Product Support
Dan.Scales
Message 2 of 4 (248 Views)
Re: Pipe Segments
12-03-2012 06:56 AM in reply to: blorich
If you are talking about the tangent lengths used in pipe bends then you can modify the defaults used by editing the "PipeBendDefaultValues.txt" file that is located in the install directory of Plant 3D.
I hope this helps.
Dan
Dan Scales
Valued Contributor
blorich
Message 3 of 4 (202 Views)
Re: Pipe Segments
12-10-2012 05:00 AM in reply to: blorich
Dan,
Thanks for the response.
I do not beleive that the tangent lenght default values is what I am talking about.  In the Project setup there is a Pipe Segment box that can not have a default value of 0, which forces a pipe spool to be placed after a fitting. the pipe bend it self is fine, its the fact that it forces me to place a spool afer any fitting.
Product Support
Dan.Scales
Message 4 of 4 (195 Views)
Re: Pipe Segments
12-10-2012 06:42 AM in reply to: blorich
OK, I understand what you need now and will log a feature enhancement request with our developers.
In the meantime you will need to manually place the flange on the elbow.
Dan
Dan Scales
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
