Hi there,
is there a way to setup a maximum cut length for a pipe in Plant 3D.
Ex: I have a 100ft lg straigth pipe and i would like to hace a clamp at every 20ft.
Can i setup a maximum cut length to 20ft so when i will route a pipe longer than 20ft, an additionnal clamp will appear and i will have 2 pipe segment?
And/or, can i simply add a victaulic pipe clamp in the middle of a pipe, splitting the actual pipe.
Thx
There's no way that I know of in the released version. We're doing some work in this area for including in a future version. Would you be interested in taking a look at what we've done so far and letting us know what you think?
If you are interested, send me an email - peter.quinn@autodesk.com
I configured something like this for a client. We created a pipe with a standard length and stored it as a block in a 'library' drawing in a 'library' project. We created a palette that picks up that block, making it possible to insert each pipe individually. Not a perfect procedure, but it works.
I want to make sure I'm clear on this. Can you install a Vic coupling in the middle of a straight run of pipe?
If not, is there a work around? I have a mixed system with buttweld fittings and Vic couplings instead of Feild Welds.
If there is no practical work around I will be forced to use a difrent software.
Please help with this.
Rod
