AutoCAD Plant 3D General DIscussion
Active Contributor
SamScopeo
Message 1 of 8 (634 Views)
pipe insultation not represented in orthoview P3D2013
634 Views, 7 Replies
01-28-2013 07:02 AM
Hi
question in the tittle
is it a P3D  bugg or a misuse on my part ?
Employee
PeterQuinn
Message 2 of 8 (627 Views)
Re: pipe insultation not represented in orthoview P3D2013
01-28-2013 09:41 AM in reply to: SamScopeo
It's not a bug, per se. The ortho feature doesn't show the insulation. Do you mind sharing an example of what you'd like to see with the insulation? It's on our list to implement, but one thing that's been slowing us down is lack of user examples of what's required.
Most examples that I've seen include a short segment showing the insulation requirements of the pipe - kind of like the iso PP insulation symbol. This is possible now. What I've been hearing is that we need to show insulation on all pipes, but exactly what's needed, along with some example drawings would be useful for the software development team.
Peter Quinn
Senior Product Manager
Active Contributor
SamScopeo
Message 3 of 8 (621 Views)
01-28-2013 11:19 AM in reply to: PeterQuinn
Hi thanks,
Ok not a bugg, I understand that it a missing in the function devellopment.
A piping layout must show the apparent dimension. So the pipe with the insulation.
This to check and see the real the volume / place take by the pipe in a area.
An example can be made in model space choose a top view and hidden render
Sam
EricNyh
Message 4 of 8 (615 Views)
01-28-2013 12:24 PM in reply to: PeterQuinn
Here's an example of how we show it, one LB pipe and one SB pipe.  We don't always use the elbow version, but it's nice to have sometimes.
Distinguished Contributor
Arun_Kumar_K
Message 5 of 8 (574 Views)
01-30-2013 07:45 AM in reply to: EricNyh
A good image attached. it will be nice to get insulation symbol at every elbows and one insulation symbol between two elbows.
Also we require flow direction symbol in Orthographic.
Product Support
gersteb
Message 6 of 8 (545 Views)
02-01-2013 01:41 AM in reply to: Arun_Kumar_K
Thank you all for your suggestions how it shall look like. Those advices will be part of the implementation of this enhancement request.
Bernd Gerstenberger
Active Contributor
SamScopeo
Message 7 of 8 (500 Views)
02-18-2013 09:51 AM in reply to: gersteb
Hi
I agree with Eric and THERMAX
It's the practices of the profession
yama21250
Message 8 of 8 (346 Views)
11-04-2013 09:33 AM in reply to: SamScopeo
Is there a solution or a workaround to show piping insulation on a ortho view?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
