why when i mesure the pipe diam prependicular in profile its less than the accurat dimension of the pipe whoever i changed the profile vertical exaggeration to 1, it still wrong?
when mesured virtical it is ok
i need help here
Can you post a screen shot of the dimension to which you are referring?
what i mean that try to draw pipe in profile then meassure the pipe diameter
vertical is ok put perpendicular is not right
I suppose that's what I'm saying...I don't get those results. Can you post a screenshot to show what you are getting? You may also want to double check catalog dimensions for your pipe.
YES I'M SURE THIS IS CIVIL 3D AND THIS PIPE IS ONLY STYLE I CHOOSED
