Pipe, Flange and Valve Problem
I have tried to model pipe, flange and valve together and they cannot be connected. Please see below list for the spec editor:
PIPE, SDR11 PE100 SERIES1 VINIDEX AS/NZS 4130 END CONNECTION: PPL
BACKING RING, TABLE D VINIDEX END CONNECTION: FL, LAP
FLANGE STUB, SDR11, VINIDEX END CONNECTION: LAP, PPL
BOLTSET, LB, STUD BOLT END CONNECTION: FL
GASKET,TABLE D, AS 2129 END CONNECTION: FL
BALL VALVE FROM CUSTOM PART END CONNECTION: FL
Pipe and flange can be connected, but I cannot put any more flange or valve on.
Can anybody please tell me what is wrong? Much appreciated.
Thank you!
Elena
Try these end connections...
BACKING RING, TABLE D VINIDEX END CONNECTION: FL, (add FF or RTJ for facing), LAP
FLANGE STUB, SDR11, VINIDEX END CONNECTION: LAP, (add FF or RTJ for facing), PPL
BOLTSET, LB, STUD BOLT END CONNECTION: (remove the endtype)
GASKET,TABLE D, AS 2129 END CONNECTION: set "Undefined_ET", add FF or RTJ for facing
Thanks & Regards,
Thanks for your reply.
I used end connections...
PIPE, SDR11 PE100 SERIES1 VINIDEX AS/NZS 4130 END CONNECTION: PL
BACKING RING, TABLE D VINIDEX END CONNECTION: FL, ( FF for facing), LAP
FLANGE STUB, SDR11, VINIDEX END CONNECTION: LAP, ( FF for facing), BV BOLTSET, LB, STUD BOLT END CONNECTION: None GASKET,TABLE D, AS 2129 END CONNECTION: set "Undefined_ET", FF for facing
GATE VALVE, PN16, PFS, PFS, METAL SEATED, TYCO WATER END CONNECTION: FL
These working very well. But I cann't put valve on it and ISO was not connect. Please see attached.
Thank you,
Elena
Good to know that the end connection mappings are working!
Can you try placing the component one by one such as Pipe -> place the LAP Flange on the pipe end ->Place the Valve on the Flange End -> then Place the Flange on the Valve end -> pipe ...?
Meanwhile, I will try it in my end to find out the problem.
Thanks & Regards,
