My Plant 3D has stopped auto-insert Tees. If I drag off the 'plus' on the pipe, it just stubs out even though stub setting is turned off. The same goes when trying to drag off an elbow. Any thoughts?
Solved by dave.wolfe. Go to Solution.
Do you mean it is working before? so what do you think the latest changes you have made? Can the Elbow and tee still be placed using spec viewer or pallet? thanks
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Could a mod please change the Title to something more appropriate? I'm pretty sure that title came from the autofill.
