AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
pipe connection to equipment failed
2 REPLIES 2
js.gomes
328 Views, 2 Replies
When i try to connect my equipment to a pipe, the program send me a error saying that can't recognize the pipe/connection.
How can i make the connection between the pipe and the equipment?
i'm using the plant 3d 2013.
2 REPLIES 2
Are the values matching on the nozzle to the pipe spec you are working on? Check those figures first.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
Thanks. You solve me half of my problem.
The problem persist when i try to conect two equipments. That's my real problem. For example, i need to connect a reactor to a filter and when i try to do that, autocad send me a error.
”Boost
