AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Pipe bend without weld point in izometri
5 REPLIES 5
1343 Views, 5 Replies
Hi Everyone
I wanna create a pipe bend without weld point in izometri.
Thank you for attention.
5 REPLIES 5
EricNyh
I would like an answer to this as well.
al.li312
Sorry,
but I would like an answer to this as well.
KenFauver
in reply to: al.li312
If you don't have a weld how is it get attached to pipe or are you referring to Bent Piping? Currently Plant 3D does not support bent piping.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
in reply to: KenFauver
Hi everybody,
I continue this topic as I have the same problem.
One question regarding bend piping : as I am using pipe bend in my model, I don't want to have a weld point before and after the bend on isometrics.
I mean, Plant is considering bend as elbows which leads to welds points before and after it and this is not the reality.
Is it possible to specify this somewhere in the isoconfig.xml or what ?
al.li312
Update to Plant 3D 2016 or higher. Better Plant 3D 2018.
”Boost
