I can't seem to find anything except THDM type nipples in the ASME Pipes and Fittings catalog in the Spec Editor for AutoCAD Plant 3D 2012. When I use a nipple in a SW fitting (ex: a SW tee) I get an error and a leak point appears. Does anyone know how to select a PE x TE nipple? Surely this must be a trivial action but the Spec Editor only lets you sort by one (1) end type (i.e. only one End Type column).
Thanks for any help or suggestions.
KDW
