AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
PE x TE Nipple AutoCAD Plant 3D
4 REPLIES 4
1442 Views, 4 Replies
I can't seem to find anything except THDM type nipples in the ASME Pipes and Fittings catalog in the Spec Editor for AutoCAD Plant 3D 2012.  When I use a nipple in a SW fitting (ex: a SW tee) I get an error and a leak point appears.  Does anyone know how to select a PE x TE nipple?  Surely this must be a trivial action but the Spec Editor only lets you sort by one (1) end type (i.e. only one End Type column).
Thanks for any help or suggestions.
KDW
4 REPLIES 4
Good question. I'm looking for the answer to this one as well....
Anyone???
jabowabo
Duplicate the item in the catalog and change the end types. Then add the new item to the spec.
in reply to: jabowabo
Not that easy. Anyone else?
PeterQuinn
Why isn't it that easy?
Peter Quinn
Senior Product Manager
”Boost
