AutoCAD Plant 3D General DIscussion
Active Contributor
lyowbeen
Message 1 of 12 (665 Views)
PCF file template
665 Views, 11 Replies
08-26-2012 10:48 PM
Hi,all!
I don't know if there is a template for the pcf file when I create isos.
Sometimes, I must modify the pcf file handly to make a better isometric. Obviously it's not very convenient. So if there is a template file, this will be esay!
Anyone knows that? Thanks!
Bin.
Yeah. I think you are right. Maybe the iso engine does that without any template.
I don't think that information is publicly available/open format, like PDF (for example).  It may be available for purchase through Alias for development purposes as part of licensing but I suspect the cost would be high.  Thats one of my major complaints about the PCF format - not documented, only accessible (reliably, anyways) with Alias-provided and -licensed software.
Employee
TomislavGolubovic
Message 2 of 12 (643 Views)
Re: PCF file template
08-27-2012 04:23 PM in reply to: lyowbeen
What do you need to update? Its all done within the Isometrics dialog box and the XML file.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Active Contributor
lyowbeen
Message 3 of 12 (640 Views)
08-27-2012 06:32 PM in reply to: lyowbeen
Thanks, Tom!
You know that we can have lots of options in the isoconfig.xml. But some of the data format can't be set up. For example, the tag is unique. Assume that we have five similar valves, and the tags are HA-1, HA-2, and so on. But in the isometric, we just need to annotate 'HA'.
So we must modify the pcf handly. If there is a template, I think we can make that more easier.
dave.wolfe
Message 4 of 12 (637 Views)
08-27-2012 07:29 PM in reply to: lyowbeen
You could modify an annotation scheme for valves to display a different property.  For example, I think the property you would want to display would be the valve code (vs the tag).  Then you'd get HA without the valve number.
We have several posts on using an xml editor for various tasks like this:
http://www.pdoteam.com/?cat=100
http://www.pdoteam.com/2012/08/editing-xml-files/
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Active Contributor
lyowbeen
Message 5 of 12 (636 Views)
08-27-2012 08:33 PM in reply to: lyowbeen
Yes. I've read all articles you post in the pdoteam.com.
The valve is only one example. We still have some other situations like this.
dave.wolfe
Message 6 of 12 (622 Views)
08-28-2012 05:07 AM in reply to: lyowbeen
I think pretty much everything in the pcf can be controlled by the isoconfig, so I recommend exploring it.  I'm pretty sure, the program just generates the data, rather than using a template to populate it.  The isoconfig can change the pcf to the point that using a template isn't really practical.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
dgorsman
Message 7 of 12 (620 Views)
08-28-2012 08:02 AM in reply to: lyowbeen
I don't think "template" is the right term for what you want.  Are you looking for the PCF technical specifications, the ones that describe what each element of the PCF file is, what it must/may contain, and in what order?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Active Contributor
lyowbeen
Message 8 of 12 (607 Views)
08-28-2012 06:38 PM in reply to: dgorsman
Yes. You quite know me! One of our needs is to use the pcf file for stress analysis programs. Since there is no way to control the pcf format, we have to modify it handly every time.
Active Contributor
lyowbeen
Message 9 of 12 (605 Views)
08-28-2012 06:39 PM in reply to: dave.wolfe
dgorsman
Message 10 of 12 (594 Views)
08-29-2012 02:30 PM in reply to: lyowbeen
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
