AutoCAD Plant 3D General DIscussion
thebearjed
Message 1 of 4 (197 Views)
P3D w/ No PID's
197 Views, 3 Replies
09-04-2012 04:03 PM
When running a project in P3D only and having no PID's input (no line numbers to chosse from) can you enter Line Numbers into the project.
ie...have a drafter type in all the line numbers so that they will be avialble to the designers at a later date.
thebearjed
Message 2 of 4 (167 Views)
Re: P3D w/ No PID's
09-05-2012 05:41 AM in reply to: thebearjed
knock...knock
Employee
TomislavGolubovic
Message 3 of 4 (158 Views)
Re: P3D w/ No PID's
09-05-2012 03:53 PM in reply to: thebearjed
In the Project Properties, have a look at the Plant3D section, navigate to where you want to edit the properties of a particular class, and you can maybe make the Line Number a pulldown from a list, rather than a string.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
Product Support
gersteb
Message 4 of 4 (110 Views)
Re: P3D w/ No PID's
09-12-2012 04:12 AM in reply to: thebearjed
Hi Jed,
Could Tomislav help you? If not I have attached a snapshot which should describe you how to add a new property 'Drafter Type' for example to the class 'Pipe'. Furthermore it will show you the way how to add a selection list to this new class. Hope this helps.
Please, if we could help you here then mark this case a resolved by clicking on 'Accept as Solution'. Thanks
Regards
Bernd
Bernd Gerstenberger
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
