When running a project in P3D only and having no PID's input (no line numbers to chosse from) can you enter Line Numbers into the project.
ie...have a drafter type in all the line numbers so that they will be avialble to the designers at a later date.
In the Project Properties, have a look at the Plant3D section, navigate to where you want to edit the properties of a particular class, and you can maybe make the Line Number a pulldown from a list, rather than a string.
Hi Jed,
Could Tomislav help you? If not I have attached a snapshot which should describe you how to add a new property 'Drafter Type' for example to the class 'Pipe'. Furthermore it will show you the way how to add a selection list to this new class. Hope this helps.
Please, if we could help you here then mark this case a resolved by clicking on 'Accept as Solution'. Thanks
Regards
Bernd
