I'm having some problems cutting spool drawings in P3D 2014. If i have a line number that has field welds on it P3D should break it into spools based on the field weld locations. The problem is that if I have more than one field weld or field fit weld on a line it breaks it at the first field weld but then drops all of the other feild welds. Not only does it not cut into multiple spools but it completely drops the welds from the spool drawings.
Anyone have any insight on this? I thought I had this working ok in 2013.
Thanks!
